  3. Group as parametric set is not working
  • Subscribers 136
  • Views 16337
cADEUser
cADEUser over 6 years ago
I grouped it like this :
And I expect 5 points  and I get 3 points  :
what am I missing ?
    It would have been useful if you'd mentioned which version you were using and which ADE (Assembler or XL). Anyway, from some tests, this appears to have been something that was broken in IC618/ICADVM181 ISR12, and is fixed in ISR13 (I just tested a pre-release build). It was working in earlier ISRs and is related to removing duplicate points in sweeps (normally a good thing, but clearly not in this case!). The CCR was 2273300 and ISR13 is due 14th August currently.
    I didn't see the issue in earlier versions, but I didn't go back too far and only tried ADE Assembler, so hopefully my trials match what you are seeing.
  • cADEUser
    cADEUser over 6 years ago in reply to Andrew Beckett
    Sorry Andrew. I should have mentioned the version number. I am using this version and I am using ADE Assembler.
    Andrew Beckett over 6 years ago in reply to cADEUser
    That's a pre-release Agile build (as the name suggests), but broadly it corresponds to IC618 ISR12. There will be a later build corresponding to IC618/ICADVM181 ISR13, which would have the fix - but in a similar timeframe to that which I mentioned below.
