  3. What's the bindkey command for ascend to top level on Cadence...
  • Views 8603
What's the bindkey command for ascend to top level on Cadence?
venkmanbuster
venkmanbuster over 6 years ago
I am trying to add a bindkey to ascend to the top level of a cell when the cell has several layers in the hierarchy and I am in lower levels. What's the bind key command for that?
  • ayayla
    ayayla over 6 years ago +1
    You can check the below one for schematic. Ctrl+w is the bindkey I use to go top level. list("Ctrl<Key>w" "schHiReturnToTop(hiGetCurrentWindow())")
    Andrew Beckett over 6 years ago in reply to ayayla +1
    Given that venkmanbuster didn't state whether this was for schematic or layout, the equivalent layout function is leReturnToTop() . This is of course assuming that he/she was asking about Virtuoso -…
  • ayayla
    This is of course assuming that he/she was asking about Virtuoso - there is no tool called "Cadence". I do wish people would ask properly framed questions!
  • venkmanbuster
    venkmanbuster over 5 years ago in reply to Andrew Beckett
    Oops sorry about that. Yes, I did refer to Cadence Virtuoso
  • venkmanbuster
    venkmanbuster over 5 years ago in reply to ayayla
    That worked! Thanks so much!
  • venkmanbuster
    Do you know if I run this command on CIW window does it replace an existing function that uses Ctrl<Key>w shortcut? Or should I first remove that function which uses this shortcut and then run this command?
    Andrew Beckett over 5 years ago in reply to venkmanbuster
    Which command? All the earlier reply did was tell you which command was used to return to the top? There was nothing shown which replaces the bindkey. If you do:
    hiSetBindKey("Schematics" "Ctrl<Key>w" "schHiReturnToTop(hiGetCurrentWindow())")
    then it would replace any existing definition of Ctrl-w with then new function (if there was one).
