  3. Setting default simulation directory to contain the library...
  • Views 15424
Setting default simulation directory to contain the library name
VLSIiitm
VLSIiitm over 6 years ago
By default, the simulation results of all cells will be under the simulation path specified by envSetVal("asimenv.startup" "projectDir" "simulationDirPath") in .cdsinit without any further hierarchy. It would be better to have a subdirectory with the library name under which simulation results of cells under this library are stored. How to modify the above line in .cdsinit to accomplish this?
Nagendra
    Hi Nagendra,
    ADE XL, Explorer and Assembler do this automatically, and you should be moving to ADE Explorer/Assembler because XL (and L) are in "sunset mode' (heading towards end of support).
    However, assuming you're talking about ADE L, you can do this with:
    envSetVal("asimenv.startup" "appendLibNameToProjectDir" 'boolean t)
  • VLSIiitm
    VLSIiitm over 6 years ago in reply to Andrew Beckett
    Thanks! It was for ADE-L.
    Yes, ADE-L is old, but haven't stopped using it completely because of its convenience!
    Nagendra
