  3. Monte Carlo re-running a MC point as Statistical corner
  • Views 18472
MonaG
MonaG over 6 years ago
I am using IC6.1.8 version and ran a Monte Carlo sampling test for 30 cases and saved a point in results detailed view as statistical corner but when I re-run the saved corner the results are identical to nominal corner and the monte carlo results are not recreated.
Any help is appreciated.
    There are two kinds of statistical corner you can create in ADE - either sequence-based or value-based. The value-based is more robust (and means you can make changes to the design; anything unchanged will get the variation in the corner). Sequence-based corners (if you have run with all or mismatch) won't work properly if you added or removed any component in the design - but they should repeat the result if nothing changed.
    Which is created depends on how you ran Monte Carlo. If you ran with a fixed-number of points (in Explorer/Assembler) and didn't go into the advanced options and turn on "save statistical parameters", then it will always save sequence-based. If you turned on the saving of these parameters, then you'd get a choice at the time you save the corner.
    You didn't say which MC run choice you ran with, or whether you're using ADE XL or Explorer/Assembler.
    Either way, i would expect sequence-based corners to also be OK if the design didn't change.
    So perhaps  you can say:
    1. Which ADE you're running
    2. How  you ran Monte Carlo (what the choices on the form were)
    3. Which Spectre sub-version  you're running (at the top of the spectre log file)
  • MonaG
    MonaG over 6 years ago in reply to Andrew Beckett
    Thank you Andrew, I think I found the problem, I mistakenly used regular model files for running "single run, sweeps and corner" instead of the MC model files.
