  3. SPICE imported .SUBCKT requires different modelname than...
  • Views 15555
SPICE imported .SUBCKT requires different modelname than given in netlist
HoWei
HoWei over 5 years ago
I do have a PDK library with an nmos device with different device and model name
libname= <pdk lib>
cellname= nmos_1p5_dw
modelname= nmos_1p5   <-- this name is provided by the modelfile
That is working fine.
Now I need to import SPICE netlists (standard cells) and the SPICE subcircuit has the following code:
     .SUBCKT … … …
     XM0 net1 net2  Vss Vss nmos_1p5_dw …  …
The import works well and the device "nmos_1p5_dw" (as found in the referenced PDK lib) is instantiated in the new schematic.
The problem now is, that the new schematic has an device instance with the following parameters:
libname= <pdk lib>
modelname= nmos_1p5_dw   <-- this name is NOT provided by the modelfile
The problem is that the modelname is equal to the cellname and this model cannot be found in the modelfile.
The simulation fails.
Is there a way during import (or in the netlist file) to declare the modelname as "nmnos_1p5" ?
  • HoWei
    Apparently the only way is to edit the netlist file and add the model parameter explicitly:
         .SUBCKT … … …
         XM0 net1 net2  Vss Vss nmos_1p5_dw model=nmos_1p5 …  …
    Then the import ofthe device parameter "model" works properly.
