  3. Plot depended design variable for a simulation with variable...
  • Subscribers 133
  • Views 10399
Plot depended design variable for a simulation with variable sweep
FormerMember
FormerMember over 5 years ago
I guess this question is not new, but I could not find any solution so far.
I am using maestro and I have a frequency simulation (eg. ac) where I sweep a design variable 'x' at a fixed frequency. I also have some dependent variable 'y=2x' (actual expression more complicated), which I want to use in an expression after the simulation. However, it seems there is no way to access the dependent variable after the simulation. I checked the results browser and can only find the fixed default value for 'y' in the 'designParamVals' folder.
Is it possible to somehow save dependent variables for different simulations with own sweeps or do I have to make a single-point simulation and do the sweep in maestro?
    ShawnLogan over 5 years ago
    Dear Paul,
    If I understand your question correctly, I believe you can compute your expression y(x) using the xval() function. For example, suppose your initial x value sweep was to study a response z(x). Using ocean or the calculator, the xval() function will return the x values from the z function using xval(z). Hence, using xval(z) as the x argument of your second function of y(x), I believe you can evaluate its value from your existing simulation data. The function xval() is documented on page 231 of the Spectre® Circuit Simulator Measurement Description Language User Guide and Reference
    Product Version 19.1 January 2020 manual at URL:
    support.cadence.com/.../techpubDocViewerPage
    I hope I understood your question correctly Paul snd this helps!
    Shawn
    ShawnLogan over 5 years ago in reply to ShawnLogan
    Hello Shawn,
    thanks for your answer. What you described is what I am basically doing at the moment. I get my x value with xval and calculate my dependent variables with the same equation I used in the variable editor. I just thought, it may be possible to access these variables directly because the xval approach seems redandant.
    There's no specific waveform saved for the dependent variable, but since it's the x-axis for all of the waveforms in the DC sweep, simply accessing it via xval is the simplest approach.
