  3. how to exclude a net in Quantus parasitic extraction
  • Views 18723
HasanArd
HasanArd over 5 years ago
I wanted to know how I can exclude a net and/or Power nets from extraction in Quantus. I want to exclude the selected net from R and C extraction.
I have tried to exclude the power nets under "filtering > Enter power Nets". For some reason that doesn't seem to be working for me!!
I would appreciate your comments on this.
I am using ICADVM18.1, Quantus20.1 ..
Thanks.
  • Saloni Chhabra
    Saloni Chhabra over 5 years ago +1
    Hi, To exclude any net(s) from both R and C extraction, you will need to use 'Excluded Nets Proper' option under 'Net Selection Mode' in Extraction tab of Quantus form, and then provide a list of nets…
  • Saloni Chhabra
    To exclude any net(s) from both R and C extraction, you will need to use 'Excluded Nets Proper' option under 'Net Selection Mode' in Extraction tab of Quantus form, and then provide a list of nets. Here's a snapshot showing the same:
    Hope this helps.
    Saloni
  • Howardt1997
    Howardt1997 over 5 years ago
    Here is the complete  guide )
