  3. Ultrasim DSPF Stitching Failed
  • Views 15044
Chao Wang
Chao Wang over 5 years ago
Recently, I want to run post-layout simulation using Ultrasim, futher more I want to using xrun+ultrasim to run co-sim.
But from the simulation results, it seems DSPF stitching failed, because the results are the same regardless of whether stitching is enabled or not.
When I check ADE->Simulation->DSPF Log, some errors are as follows:
ERROR  (STITCH-0040)(:38434) : Element I_counter.xi_buf_delay.xi24.xmn0 not found.
I can find  I_counter.xi_buf_delay.xi24.xmn0 instance in spf file and schematic, why the stitching failed?
Is there any other post-layout simulation method using Ultrasim?
Thanks and regards,
Chao
  • Chao Wang
    It seems the simulation is successful even though this error reported.
    But I encoutered another fatel error: "UltraSim is terminating, it received a Segmentation fault signal."
    This error will block the simulation process, so I can't get a result.
    Chao
    Andrew Beckett over 5 years ago in reply to Chao Wang
    Chao,
    Please contact customer support. Debugging this without seeing the data is going to be rather hard.
  • Chao Wang
    Chao Wang over 5 years ago in reply to Andrew Beckett
    Thanks Andrew.
