  3. fully differential opamp stb simulation
  • Views 28994
AllenD
AllenD over 6 years ago
Hi team
The schematic of the fully differential amplifier is in the attached pictures. I want to simulate the differential gain/stb and common mode feedback loop stb
Fig1 fully differential amplifier circuit testbench
Fig 2 Inside the fully differential opamp is my core fully differential amplifier and CMFB amp
Fig 3 My core amplifier and I put the CMDMprobe here
My question is that I did transient and stb simulation with cmdm probe. in the plot below, the transient plot is on the left. Red is the input the green is the output, which suggests a stable amplifier with a positive gain. But the stb simulation with CMDM=-1 suggests the plot on the right--the gain is negative.
Can you please let me know what I did was wrong? Or what other info do you need to help me diagnose?
MD
    ShawnLogan over 6 years ago
    Dear AllenD,
    I must be overlooking something, but I don't see any instances of the differential probe diffstbprobe  in your test bench nor in your differential amplifier. Am I overlooking it?
    Shawn
  • AllenD
    AllenD over 6 years ago in reply to ShawnLogan
    Hi Shawn
    Thanks for your reply!
    I did not use that probe because I used CMDM probe (in fig 3) and put "-1" in the probe parameter. To the best of my knowledge, this will simulate the differential mode...?
    I tried to insert the diffstbprobe, as you suggested, at the exact same location of my previously CMDM probe. Then updated the probe instance terminal, mode type to differential. But the result is still wrong (as yellow and purple). But the common mode simulation is in agreement with CMDM probe with parameter “=1"
    ShawnLogan over 6 years ago in reply to AllenD
    Dear AllenD,
    I apologize, but I must be blind - I'm not sure which of your figures is Figure 3, but I don't see an instance of the CMDM probe you mention - sorry!
    In any case, the use of diffstbprobe is recommended for both common-mode and differential mode stability analyses as documented at URL:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nSkWEAU&pageName=ArticleContent
    Further its location is quite important in your circuit. There is also an example on the Cadence support site at URL:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nSorEAE&pageName=ArticleContent
    in case you have not seen that already.
    I apologize, once again, if I am overlooking your probe. Maybe my display is not showing your entire graphic.
    Shawn
