  3. plotting more than one variable on x-axis in viva
  • Views 14583
harrymadaan
harrymadaan over 5 years ago
Dear All,
One question : I would like to put more information in one plot. Means for example if i have simulation results for voltage  across corners and temperatures than i would like to plot this whole information in one plot with temperature and corner on x-axis and voltage on y-axis. Something like shown below
This can be easily done in excel sheet but i would like to know if same can also be done in viva so as to avoid going through excel.
Thanks in advance.
Br, harry
    Hi Harry,
    No, this can't be done. Potentially the x-axis values could be recreated to be a combination of the corner name and temperature for each point, but that would involve reconstructing the x-axis data, and even then it wouldn't look like you describe.
    I can see why this would be useful - probably worth contacting customer support?
  • harrymadaan
    harrymadaan over 5 years ago in reply to Andrew Beckett
    Thanks for the prompt reply Andrew.
    Sure i would contact the support if some solution is feasible.
    Br, harry
