  3. unbound variable - device property issue
  • Views 3093
sjwprcker
sjwprcker over 5 years ago
I set a variable "L350" to NMOS transistor length and sweep the variable. It works well.
However, after I try parameterization on its length, accidently cds shows the unbound variable issue of "L350", CIW report: CDF parameter function has problem. And when I open property of NMOS transistor by "Q", all CDF info disappear.
I can forcely open property assistant view, and find many yellow exclamation mark as below. Btw, the netlisting and simulation still work with this issue.
Is there anyway to recover the CDF settings as before? Thanks!
    The error message is pretty clear - report this to the supplier of the PRIMLIB library, which is presumably AMS (given by the callback name)? What it means is that the CDF callback for this field doesn't support variables being used in the length field - most likely they are trying to evaluate the value using evalstring() which won't work and is not safe. Not sure why all the properties would go missing on the edit properties form, but either way you need to take this up with the provider of the PDK. It's their code that is breaking.
  • sjwprcker
    sjwprcker over 5 years ago in reply to Andrew Beckett
    Hi Andrew, thanks for your feedback. I will contact with them.
