  3. Problem in running QRC Quantus in Cadence Virtuoso
  • Views 15602
Senan
Senan over 5 years ago
We Newley installed our PDK, when I try to run the QRC I receive the following error message,
Is it harmful to ignore ?
Thank you very much
    No idea - it probably depends on how critical the thing that is going wrong is! Best to contact the foundry, as my guess is it is customisation they provide? Andrew
    Andrew Beckett over 5 years ago in reply to Senan +1
    Not really sure what you're asking here. Share what? This is some issue specific to a particular foundry's PDK, and so how generally applicable what you've found is, I'm not sure. Andrew
  • Senan
    Senan over 5 years ago in reply to Andrew Beckett
    Dear Andrew
    Thank you for your reply
    I ignored the error, and I continued to the extraction process, the run completed successfully but the netlist is not correct. I have documented this issue, is it possible that I share it here ?
    Thank you
  • Senan
    I was asking if I can share the error report, but as you said, it is mostly PDK foundry problem,
    Thank you
