  3. Print statements with subcircuits
  • Replies 7
  • Views 16551
Omar123318
Omar123318 over 5 years ago
Hello, I have a question regarding spectre netlist language
I know If I have a circuit containing MOSFETs, I can use a print statement to save specific parameter value to a file with the following statment:
print M0:vth,
+name = dc addto = "myfile.txt"
I wonder How can I use do the same If my mosfet now is defined inside subcircuit I?
I see nothing about this in spectre help
    You would use: print I1.I4.M0:vth ... Where I1.I4.M0 is the hierarchical path of instance names down to the transistor in question. Andrew.
    Andrew Beckett over 5 years ago in reply to Omar123318 +1
    Perhaps the simplest would be just to add: myoppoint info what=oppoint where=file file="myoppoint.txt" to your netlist. This will save all operating point info for every device into the specified file…
    You would use:
  • Omar123318
    Omar123318 over 5 years ago in reply to Andrew Beckett
    Thank you very much. This is really helpful.
    I wonder if there is a way to print all MOSFETs' operating points in certain subcircuit using print statement?
    ShawnLogan over 5 years ago in reply to Omar123318
    Dear Omar122318,
    The following link provides a means of printing all the DC operating points of the devices in your circuit.
    support.cadence.com/.../ArticleAttachmentPortal
    I hope this provides what you were hoping to accomplish!
    Shawn
  • Omar123318
    Omar123318 over 5 years ago in reply to ShawnLogan
    No, I want to do it from the netlist not the gui.
    to your netlist. This will save all operating point info for every device into the specified file. As with other spectre instances/analyses, you can use whatever word you like for instance name of the info analysis as long as it is unique.
  • Omar123318
    If I do it this way, can I filter the parameters to be printed?
    No. You could probably also use the print statement approach with wildcards for the component name.
