  3. How to evaluate the variable in a maestro measurement expression...
  • Views 19552
How to evaluate the variable in a maestro measurement expression and not treat it as a literal string
Genas
Genas over 6 years ago
I am trying to measure some signals and it is constantly evaluating it as a string and not capturing it as a variable
Example:
This scenario works perfectly --> maeAddOutput(strcat("read" "avg") title ?outputType "point" ?expr "average(VT(\"/net_read\"))")
But I am trying to use a variable for the signal name, how can I achieve that.?
Example: name = “net_read”
maeAddOutput(strcat("read" "avg") title ?outputType "point" ?expr "average(VT(\"/name\"))")
 How can I tell it to replace name with the variable because it is currently processing name as an input  signal and not the content (net_read)
What is the correct syntax to insert variable in a maestro measurement expression
    ShawnLogan over 6 years ago
    Dear Genus,
    I believe I understand your question. You are unable to use a variable name as. a signal and have it be evaluated in an Assembler/Explorer expression.
    When I examined the expression, one item that came to mind immediately is that the syntax you appear to be using to access the signal name as a variable does not appear correct to me. The first argument of the VT() function is a string with the net name of interest. Hence it is not expecting a variable.
    What I do, which appears to work, is define a variable as a wave and then I am able to use that  variable in a more complex expression. For example, using your expressions:
    name = VT("/net_read") -- name is the variable and is defined as a wave by the VT() function.
    then, in your expression:
    average(name)
    When you used the variable name in your expression, it is interpreted as a string. Did I understand your question correctly? I hope so...
    Shawn
  • Genas
    Genas over 6 years ago in reply to ShawnLogan
    Hi Shawn,
    Thanks for the response, you got the question.
    When I used the variable name in your expression, it is interpreted as a string but I don't want this behavior, I want the content to be interpreted not the variable name.
    I modified it just as you recommended and it is still not evaluating the variable, rather I get this error "*Error* _averageMethod: can't handle _averageMethod(nil)".
    Maybe I missed this part "define a variable as a wave ".
    How can I define it as a wave?
  • Genas
    Genas over 6 years ago in reply to Genas
    Sorry for the confusion, I meant "When I used the variable name in my expression"
    I assume (if I've understood you correctly) you want in your SKILL code to do this:
    maeAddOutput(strcat("read" "avg") title ?outputType "point" ?expr lsprintf("average(VT(\"/%s\"))" name))
    In other words, you'd have to use normal string manipulation functions to build the expression. BTW, lsprintf is essentially the same as doing sprintf(nil ...)
  • Genas
    Genas over 6 years ago in reply to Andrew Beckett
    Thank you very much, this is exactly what I was looking for.
    Hey Andrew, I think you should take over the cadence customer service because I contacted customer service and the rep told me this is not possible with skill that i have to use the signal name directly.
    Andrew Beckett over 6 years ago in reply to Genas
    To give my colleagues in customer support the benefit of the doubt, it may just have been that your question was not that clear. Given that Shawn also didn't get what you meant, and I had to guess, I suspect my colleagues also misinterpreted your question. Thanks for the feedback though (even though it's not really a scalable option!)
