  3. Edit Synchronous clone
  • Views 14585
budman
budman over 5 years ago
I am trying to clone resistor chains so they can be all matched.
In the generate clones form I do a search. The tool finds the instances in the pattern mostly.
It selects instance name in other chain. How to I edit the clones found to change the instance name?
When I click edit i can only change the position of the instance under connectivity target menu not the instance name.
    I don't entirely understand what you mean. This would be much simpler if you could just show an application engineer the problem via a screen-sharing session, which can be arranged if you contact customer support.
