  3. Limit License usage (not number of jobs)
  • Views 18492
HoWei
HoWei over 5 years ago
HI,
we have a limited number of simulation licenses for our users and we want to avoid to use up all licenses at a time.
Currently the user can only set the number of parallel jobs to run, but depending on the jobs analysis (Spectre, APS Base, APS RF, APS Multicore) a different number of licenses is checked out.
Is there a way to set the max. numbers of licenses per user ?
For example the user can set his limit to 10 licenses (e.g. for license:  Virtuoso_multi_mode_simulation) ?
BR
Holger
    Hi Holger,
    You can do this via the license options file (so it's a central setting, not a user preference):
    How can I restrict a user to a certain number of seats of a license feature?
  • HoWei
    HoWei over 5 years ago in reply to Andrew Beckett
    as you wrote, this is a general setting (mostly done by admin) on the license server side.
    I am wondering if the user himself could restrict the number of licenses used ?
    What happened for example is, that I changed from a transient simulation to a PSS/Pnoise simulation and it took 5 licenses per job (instead of 1 license for Spectre).
    Now, we (users) have to check the license usage every time we start a simulation (sometimes its not clear what number of licenses is used in different simulations).
    I am looking for a way to set a personal limit of licenses to be used.
    Any idea ?
    BR
    Holger
    Andrew Beckett over 5 years ago in reply to HoWei
    Hi Holger,
    I'm not aware of any other real way of doing it. There's a client-side filter mechanism where you can define a script pointed to by $CDS_LICFLTR which gets passed the feature name and version (but not the quantity) and you can use that script to allow/deny the license access (based on the return value of the script). Potentially this could keep track of how many are in use by a particular person and at least keep it broadly under control (although I guess you could have 9 in use and then ask for 5 or 6 say, and that would take you above your 10 target - but that would be at least in the right ball-park). So that would probably be the way that I did it (either doing a live lmstat -f feature -c $CDS_LIC_FILE to check availability, or maybe doing a periodic cache to improve performance as this could be slow otherwise).
    I've also seen queueing systems also try to manage license usage by having job pre-filter scripts to allow a job to be started or not based on sufficient licenses within an allowed user-resource.
  • Frank Wiedmann
    Frank Wiedmann over 5 years ago in reply to HoWei
    You could try to write a script that runs Spectre with the +query command-line option (see https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nb0JEAQ ) before starting the actual simulation. Of course, if you are running several simulations in parallel, you will have to keep track of the current number of used licenses yourself.
