  3. "*.SCALE" is not supported. Use ".OPTION SCALE" instead
  • Views 2106
SrBraj
SrBraj over 5 years ago
Hi
I am running the PVS LVS through the skill scripts and getting the below mentioned warning message on my unix terminal:
"WARNING (NVN-13003): "*.SCALE" is not supported. Use ".OPTION SCALE" instead or specify  'lvs_cdn_flow_options -cdl_use_scale' in the rule file."
While I run the LVS from the PVS GUI, I don't get this warning in the unix terminal, but lvs report file has this warning .
Could you please tell me that how to fix this warning message.
PVS version used: 19.12-64b, virtuoso: 6.1.8-64b
Thanks and Regards
Saurabh
    For me, it appears in the log when running from the UI too. If however, I add some additional PVL rule file containing:
    then the warning goes away. Perhaps you have this in the PVL when running from the UI?
