  3. Layout becomes invisible when zoom out a bit
  • Views 15435
BaaB
BaaB over 5 years ago
I'm having problem with Virtuoso Layout Suite L (version IC6.1.8-64b.500.8).
Whenever I zoom out my layout a bit, it becomes invisible.
Normally you could zoom out much more than that and still visible.
What would be the solution?
    What do you have set for Resolution on the Options->Display form. Normally things wouldn't become completely invisible (even with Moderate) - but perhaps you can experiment with different settings for Resolution?
  • BaaB
    BaaB over 5 years ago in reply to Andrew Beckett
    Resolution is medium. I tried to set resolution higher and it works. Thanks!
