  3. maestro test naming rules
  • Subscribers 133
  • Views 15643
dhanf
dhanf over 5 years ago
by default new or copied testcases are named like <libname>:<cellname>:<number> seperated by double point. Is there any chance to change these default separator?
   Daniel
    Daniel,
    In IC6.1.8/ICADVM18.1 ISR13, the default behaviour was changed to use underscore instead of colon in the testname as the separator (including for the unique part at the end).
    In older versions, you can change the default behaviour by defining a function axlCustomADETestName to control your preferred naming policy. In Virtuoso, do Help-> and in the search box at the top, type
    and you'll find the help on this.
  • dhanf
    dhanf over 5 years ago in reply to Andrew Beckett
        Daniel
