  3. Simulation error undefined symbol: voPopErrSetHook
  • Views 14980
sidm
sidm over 5 years ago
Hi All,
I am running spectre on a netlist which throws the below error.
Will be helpful if you can kindly suggest what can be the issue ?
The circuit is subjected to sp analysis but I have generated both netlists one with just DC operating point analysis enabled and one with sp analysis enabled. In both cases the simulation is failing.
thanks
    My guess is that you have spectre from the SPB tools (Allegro) in your path. This is an unfortunate hangover from using parts of spectre (but not all of it) in the Allegro installation.
    You need to make sure that you have spectre from a SPECTRE release in your UNIX path before the Allegro (SPB) paths. So take a look at what (in the UNIX shell):
    which spectre
    returns. If it's returning spectre from an SPB installation, you need to adjust the order in your $path (if using csh) or $PATH (if using bash/ksh) to ensure the spectre from SPECTRE181/191/201 (whichever you're using) comes first.
  • sidm
    sidm over 5 years ago in reply to Andrew Beckett
    you are correct, i rectified the spectre path. Thanks , this is very helpful otherwise it would have been very difficult to catch this issue.
    regards
