  3. Turn off 1/f noise in Transient Noise simulation
  • Views 3829
Jessica Wu
Jessica Wu over 5 years ago
Hi everyone,
I got a question here: how could I turn off the flicker(1/f) noise of a circuit in Transient Noise simulation?
Please let me know if you have any clue! Thanks a lot!
Best,
Jessica
    Jessica, On Simulation->Options->Analog, on the Main tab, scroll to the bottom, and set the Noise Contribution to off . Then below that set noiseoff_type to flicker . In the Instance List field you could…
    Andrew Beckett over 5 years ago in reply to Jessica Wu +1
    Presumably. The option has been available for a pretty long time though and unfortunately my ESP circuit is broken so I don’t know which versions (IC and SPECTRE) that you’re using.
    Jessica,
    On Simulation->Options->Analog, on the Main tab, scroll to the bottom, and set the Noise Contribution  to off. Then below that set noiseoff_type to flicker. In the Instance List field you could select all the transistors, or probably just put "*" in the field. This should then just turn off the flicker noise for all devices.
  • Jessica Wu
    Jessica Wu over 5 years ago in reply to Andrew Beckett
    Thank you for your help! I didn't find "Noiseoff_type" when I scrolled down, just like the figure below shows. Is it because my cadence version is too old?
    Jiajia
  • Jessica Wu
    Thank you! Then I think my cadence version is too old. Thanks again!
    Best,
    Jiajia
