  3. Generating schematic using pin information from layout
  • Views 14002
sidm
sidm over 5 years ago
Hi All,
I have an IC layout and it's pin information. I need to create a pin only schematic for this layout. The no of pins are more than 150 so is there a way to create this pin only schematic apart from manually placing one pin at a time ?
thanks
  • sidm
    Also is there a way to generate a symbol view from layout itself ?
  • Frank Wiedmann
    Frank Wiedmann over 5 years ago
    Maybe you can use this: Automatically Creating a Cellview from a Pin List
