  3. How to run the routine CCSputOnGrid.il?
  • Views 14001
BaaB
BaaB over 5 years ago
I'm trying to run the code for correcting offgrid error here.
The first step is :
a. Load the SKILL procedure via .cdsinit file/CIW
  load("CCSputOnGrid.il")
I did that but got the error *Error* load: can't access file - "CCSputOnGrid.il".
I think the code should be put in some folder?
    ShawnLogan over 5 years ago in reply to BaaB +1
    Dear Baab, I am just glad it worked for you! Thank you for letting us know! Shawn
    Dear BaaB,
    Did you try:
    load("./CCSputOnGrid.il")
    where the CCSputOnGrid.il file is in the same directory as the directory where you launched the CIW?
    Shawn
  • BaaB
    BaaB over 5 years ago in reply to ShawnLogan
    Thank you.
    Dear Baab,
    Shawn
