  3. Calibre / PEX / During Calibre view creation / *Error* close...
  • Subscribers 126
  • Views 5676
Calibre / PEX / During Calibre view creation / *Error* close: argument #1 should be an I/O port (type template = "p") - nil
sl933
sl933 over 4 years ago
When I run PEX (passes LVS) and try to create a Calibre view, it goes through "Running Back Annotation Flow", then it errors out:
Calibre View generation encountered a fatal Error.
Please consult the logfile for messages.
The only error message from the log I can see is this:
I have been digging forums, etc. but cannot seem to find what is wrong with this PEX.
What is argument #1 and type template "p" anyways?
Sunwoo
PS I am using "sub-version IC6.1.8-64b.500.6 "
  • Quek
    Quek over 4 years ago
    Hi Sunwoo
    The error message is saying that the input to the "close" SKILL should be a file handle. "p" refers to the input data type. In this case, it means "I/O port" type. As Calibre is a tool from Mentor Graphics, would you please get more help from Mentor's forum?
    Best regards
    Quek
  • sl933
    sl933 over 4 years ago in reply to Quek
    Thanks! It turned out that parts of the PEX code we got from the foundry had inconsistent port names (i.e., some devices in the code had 'GND' ports while the other devices had 'VSS' ports).
    Cheers,
    Sunwoo
