  3. ADE Assembler evaulates expression prior to simulating ...
  • Views 3861
ADE Assembler evaulates expression prior to simulating - long wait
jehh
jehh over 5 years ago
Based on feedback from Andrew Beckett, in another thread, I recently moved a simulation setup to the LSCS job control mode, instead of ICRP.  Now, every time I launch I get a ton of errors printed in the CIW, along the line of ERROR (ASSEMBLER-2709): Evaluation returned 'nil'.
Since I have a significant amount of errors here, it takes quite some time, before all these errors are printed, and the simulation even starts (half the time from I press simulate, to it finishes, is at least this waiting for this). When the simulations are done, none of these errors are actually true errors.
It seems most likely that LSCS calls some expression evaluation, prior to launching a simulation, evaluating none-existing expressions and then waits until this is done.
Can this behaviour be modified or circumvented? I've looked in the user guide, to no vail.
Versions: Virtuso 6.1.8-ISR14, Spectre 20.1.base
Br,
Christian
    ShawnLogan over 5 years ago +1
    Dear Christian, Is there any chance you are creating your netlist based on a config view that is an extracted view? If so, I am wondering if the expression errors generated using the LCSC based job…
    Dear Christian,
    If so, I am wondering if the expression errors generated using the LCSC based job policy are a result of an issue detailed in the Sourcelink note at URL:
    support.cadence.com/.../ArticleAttachmentPortal
    Basically, there is an issue evaluating expressions using the nomenclature of some extracted view nets. A  workaround is provided which proposes to add the following to your .cdsint file:
    envSetVal("maestro.exprEval" "binaryName" 'string "virtuoso")
    Is there any chance this might apply in your case given the nature of your Assembler expressions?
    Shawn
    Dear Christian,
    Shawn
  • jehh
    jehh over 5 years ago in reply to ShawnLogan
    Hi Shawn,
    Thank you, this seem to have done the trick - all-though I am running ISR14, and the link you provided says it should be fixed. Might be that the maestro view was created in ISR12?
    None the less, it is now running smoothly, thank you.
    BR,
    Christian
    ShawnLogan over 5 years ago in reply to ShawnLogan
    Dear Christian,
    Great! I am happy to read that this avoids the expression errors and that me lag!
    Thank you, very much, for letting us know!
    Shawn
