  3. How to index spectre vector parameters (even possible?)...
  • Views 15538
How to index spectre vector parameters (even possible?)?
drdanmc
drdanmc over 5 years ago
Is it possible to have a vector parameter as a top level design variable and then pick out elements from that inside of a subckt based on an index parameter?  The following shows what  tried and hopefully it is clear what the desired result would be.
simulator lang=spectre
global 0
parameters MYTOP=[3.3 2.7 1.8 5.0]
subckt my_subcell VOUT
parameters MYINDEX=0
  // this one gives an error:
  V0 (VOUT 0) vsource dc=MYTOP[MYINDEX] type=dc
  // no error on this, but of course that isn't what I was looking for.
  //V0 (VOUT 0) vsource dc=MYINDEX type=dc
ends my_subcell
I7 (OUT3) my_subcell MYINDEX=3
I6 (OUT2) my_subcell MYINDEX=2
I5 (OUT1) my_subcell MYINDEX=1
I4 (OUT0) my_subcell MYINDEX=0
R3 (OUT3 0) resistor r=1K
R2 (OUT2 0) resistor r=1K
R1 (OUT1 0) resistor r=1K
R0 (OUT0 0) resistor r=1K
dcOp dc write="spectre.dc" oppoint=screen
The above trial gives
Cannot run the simulation because syntax error `Unexpected identifier "MYINDEX". Expected integer or operator' was encountered at line 17, column 33. Correct the syntax error and rerun the simulation.
Thanks so much
-Dan
    Dan,
    This is not possible, as spectre doesn't have an array index operator for vectors in the netlist language. One approach would be to define a function like this:
    real getMYTOP(real myindex) {
        return myindex==0 ? 3.3 : \
    	myindex==1 ? 2.7 : \
    	myindex==2 ? 1.8 : \
    	5.0
    and then use getMYTOP(2) or getMYTOP(1) etc to retrieve the value:
    R1 (n1 0) resistor r=getMYTOP(0)
    R2 (n2 0) resistor r=getMYTOP(1)
    R3 (n3 0) resistor r=getMYTOP(2)
    R4 (n4 0) resistor r=getMYTOP(3)
    My preference would be to not do a floating point comparison, so I would round to the  nearest before comparing (just in case):
        return round(myindex)==0 ? 3.3 : \
    	round(myindex)==1 ? 2.7 : \
    	round(myindex)==2 ? 1.8 : \
    	5.0
  • drdanmc
    drdanmc over 5 years ago in reply to Andrew Beckett
    To close the loop on this, I ended up using a Verilog-A model instead of trying to directly do it with spectre primitives.  Verilog-A in spectre is able to accept a vector parameter and an index and then pick out the desired one.
    parameter integer slots = 4;
    parameter integer valArray[0:(slots-1)] = '{slots{0}};
    parameter integer valIndex = 0;
    Then I can use valArray[valIndex] to pick out values.
