  3. Changing Monte Carlo Seed automatically
  • Replies 7
  • Views 18550
MonaG
MonaG over 5 years ago
I wanted to know if there is a way to automatically set seed for Monte Carlo simulation to a random number in each run like cpu time, date, ... ? My version of Cadence is IC6.1.8.
    ShawnLogan over 5 years ago
    Dear Mona,
    I am confused by your question. Each sub-run within a Monte-Carlo run uses a random variable independent of the prior run when choosing the "Sampling" algorithm. The seed does not impact other sub-runs other than the first. Is this what you wanted? It will not convergence as quickly as other Monte-Carlo algorithms (including the default method).
    Shawn
  • MonaG
    MonaG over 5 years ago in reply to ShawnLogan
    Thank you for your reply. From what I learned, the seed if it is not set it would be the default value 12345. When I set the seed to be default in each run I get the exact same result. But when I change the seed I get different results. Now I want the seed to change in each run automatically. I hope I cleared the question.
    ShawnLogan over 5 years ago in reply to MonaG
    Dear Mona,
    I think something may not be correct in your setup. If you run a series of N Monte-Carlo simulations using the default seed value, and you have either mismatch or process set to vary (or both), each of the N runs will use different amounts of variation and will not produce the same result. There is no need to randomly assign a new seed for the remaining N-1 runs in the simulation set.
    Shawn
  • MonaG
    I guess I have explained the issue in a wrong way. I run a Monte Carlo simulation with 100 samples, and yes the simulation results are different for each 100 samples. But when I again run Monte Carlo for another 100 samples, without changing the seed, I get exactly the same results for each sample as I did before. I mean Sample 1 of the first run is equal to sample 1 of the second run. and so on. But I want to get different results for all 100 samples when I run a new Monte Carlo, which I guess it is possible by changing the seed.
    Dear Mona,
    Ahah! Thank you for the explanation. The behavior you are experiencing is expected and normal.
    Yes. you are correct. Simply change the seed. In most cases, people want to be able to replicate the same statistical case in order to compare any potential changes to the netlist.
    Shawn
  • MonaG
    Yes but instead of changing the seed each time manually, I wanted to know if there is any setting that can set the seed to a random number like date, cpu time or ...
    Dear Mona,
    I am afraid I do not understand your motivation for changing the seed "automatically" for each Monte-Carlo set of simulations. Why would you want to do this? I think this may be why the feature has not been requested as one usually does want to use the same seed when evaluating a Monte_Carlo set for design iterations.
    I also see several ways to what I believe will have a similar effect:
    1. Change the starting number of each Monte-Carlo simulation set from 1 to some other number.  You might be able to make the starting number a variable and assign it with a SKILL script before your simulations start if you know SKILL.
    2. Increase the number of simulations in your Monte-Carlo set and then analyze the data for non-overlapping regions of the Monte-Carlo interactions. (i.e., set N to, say, 1000, and study the statistics of output simulations 1 - 200, 201 - 400, 401 - 600, etc...)
    Shawn
