  3. How to Describe Branch Current with Bsource
  • Views 14995
Chiaos
Chiaos over 5 years ago
Hi, I'm new spectre user.
I found simulator reference with GOOGLE.
It mentioned that we could use this syntax:
name (node1 node2) bsource behav_param param_list
subckt as below
vsrc (P 1) DC=0
r1 (1 N) resistor r=1
bsrc (1 N) bsource i = {sgn(i("vsrc:1"))*ABS(i("vsrc:1")**2)/2000)}
I got these error message:
1. ERROR (SFE-874): "xxx.scs" 16: Cannot run the simulation because syntax error `Unexpected block statement "{"' was encountered at line 16, column 20. Correct the syntax error and rerun the simulation.
2. ERROR (SFE-874): "xxx.scs" 16: Cannot run the simulation because syntax error `Unexpected quoted string ""vsrc:1". Expected end of file or end of line' was encountered at line 16, column 27. Correct the syntax error and rerun the simulation.
3. ERROR (SFE-709): "xxx.scs" 16: No master specified for instance `ABS'
4. ERROR (SFE-709): "xxx" 16: No master specified for instance `i'.
Is there something illegal? (Except 1, 3)
  • Frank Wiedmann
    Frank Wiedmann over 5 years ago +1
    Are you sure that the curly brackets are legal syntax? You can get some more information by typing spectre -h bsource at the Linux prompt. I didn't see any curly brackets in these examples.
    Andrew Beckett over 5 years ago in reply to Frank Wiedmann +1
    Frank's right. There shouldn't be curly brackets here. BTW, there's no need to use google to find the simulator reference. It's in the SPECTRE installation (under the doc directory, or you can run <SPECTREinstDir…
  • Frank Wiedmann
    BTW, there's no need to use google to find the simulator reference. It's in the SPECTRE installation (under the doc directory, or you can run <SPECTREinstDir>/bin/cdnshelp to open it then). If you found via google, it's probably somebody breaking the license agreement as you're not allowed to re-publish our manuals. I occasionally find very old documentation this way.
  • Chiaos
    Thank you, Frank & Andrew.
    I've removed brackets, but there's still error messages.
    Error found by spectre in `xxx', during circuit read-in.
        ERROR (SFE-2309): "xxx.scs" 16: Function `SGN' is either undefined or it is a dynamic function whose arguments are behavioral expressions. This is not allowed.
        ERROR (SFE-2309): "xxx.scs" 16: Function `ABS' is either undefined or it is a dynamic function whose arguments are behavioral expressions. This is not allowed.
    Is sgn(x) & abs(x) illegal in bsource?
    These function in a protection to avoid current i("vsrc:1") through opposite direction  when connect in opposite pins.
    Andrew Beckett over 5 years ago in reply to Chiaos
    That's because Spectre is case sensitive. The functions are sgn and abs, not SGN and ABS. In your original example above you had sgn in lowercase and ABS in uppercase, so presumably you've changed them both to be uppercase? Change them to be lowercase and that should fix it.
