  3. How to model bidir switch in RNM
  • Views 16776
dontknow
dontknow over 5 years ago
I was wondering if there was a way of modelling bidir switch.
Using code, I always have a problem of propagating signal.
For instance:
module bidir_sw( a, b, ctrl);
inout a;
inout b;
inout ctrl
wreal a;
wreal b;
logic ctrl;
// this will only work from b -> a
assign a = (ctrl == 1'b1) ? b : `wrealZState;
// this will only work from a -> b
assign b = (ctrl == 1'b1) ? a : `wrealZState;
endmodule
Is there an easy way to make it work both ways, using XCELIUM ?
  • Frank Wiedmann
    Frank Wiedmann over 5 years ago
    How about the Rapid Adoption Kit Bidirectional WREAL Switch Modeling using $SIE_input Based SV-RNM Transmission Gate?
  • dontknow
    Hi Frank,
    thanks for reply.
    Can I do it using vams ? Or SystemVerilog is the only way to achieve it ?
  • Frank Wiedmann
    Frank Wiedmann over 5 years ago in reply to dontknow
    It seems to be possible with VAMS as well, if I read the manual section Writing Bidirectional Model Behavior correctly.
  • dontknow
    dontknow over 5 years ago in reply to Frank Wiedmann
    Hi Frank,
    sorry to bother you again, but I still don't understand hot the whole thing works. Would yoy be able to provide me with vams module that does behaves like a bidirectional  switch ?
    Thank you,
    Gianluca
  • Frank Wiedmann
    The vams module is given in the manual section I mentioned. I don't think that I am allowed to post the code here (someone from Cadence might be able to do so).
