  3. Differential Pair Measurement
  • Views 13947
KenKim
KenKim over 5 years ago
I would like to make a differential pair measurement, that is between one node of a floating capacitor to VSS. How do I go about doing this? Thank you.
    ShawnLogan over 5 years ago in reply to KenKim +1
    Dear KenKim, KenKim said: What I meant was a differential voltage measurement between the cap node( node that touches the Gate and Drain of the FETs) and VSS. Thank you for the added information…
    Dear KenKim,
     I may not have understood your question, but it seems you just need to define an output as the difference in your floating terminal net and VSS. Have you tried that?
    Shawn
  • KenKim
    KenKim over 5 years ago in reply to ShawnLogan
    Dear KenKim,
    Thank you for the added information. It still seems all you need to do is define an output signal whose voltage is between your node "cap" and your node "VSS". Am I still overlooking your issue? I apologize if I am!
    Shawn
  • KenKim
    Thank you, I will try this, it makes sense. No need to apologize, you were not overlooking my issue, further more, you took time to help me out. Thanks again.
