  3. Consistent path to results for corner simulation?
  • Subscribers 136
  • Views 14550
Mike Bichan
Mike Bichan over 6 years ago
I would like to know whether the results of corner simulation can be made to appear in a consistent directory path.
What I see is that corner simulation causes the results to go into numbered directories, but the numbers are not necessarily predictable.
Example: results/maestro/Plan.1.Run.0/1/transient/psf
I am using ADE Assembler.
For reference, what I am trying to do is the following:
- run a transient simulation with certain design variables needed to achieve faster settling time
- use the spectre.fc from the transient to run a pss simulation with slightly different design variables needed to ensure low noise
- then run pnoise and pxf from this pss
I am using a Run Plan to achieve the change in design variables.
But I need the pss run to point to the spectre.fc for the corresponding corner and the location does not seem to be consistent/predictable.
-Mike
    Hi Mike,
    Rather than worrying about precisely where it is going to place things, I would add an output on the first test which is running the transient which is called something like "FINALDC" and has an expression:
    sprintf(nil "%L" strcat(asiGetNetlistDir(asiGetCurrentSession()) "/spectre.fc"))
    The result will then be a string which is the path to the spectre.fc from that run. Then have a variable for the nodeset path in the second test in your run plan, set the nodeset (readns) or ic (readic) - whichever you're using to be VAR("NODESET"). Set the variable NODESET to be calcVal("FINALDC" "FirstTest") or similar (calcVal has a bunch of options depending on whether you want the simple one-to-one mapping of corners/points in the second run to the equivalent point in the first run, or you may be able to select a different point - depends on what you're trying to do). You could also pass the variable this way in the run plan - but the idea is essentially to get the first test to output where it stored its data, and have the second test consume that output.
