  3. Can we use $table_model() in verilogAMS
  • Views 14702
RFStuff
RFStuff over 5 years ago
Dear All,
I have used $table_model() in VerilogA.
But while using it in Verilog or VerilogAMS, I am seeing errors.
So, Can we use $table_model() in verilogAMS ?
Kind Regards,
    Yes. Presumably there's an error in your code, but this is certainly supported in Verilog AMS.
  • RFStuff
    RFStuff over 5 years ago in reply to Andrew Beckett
    Thanks Andrew for the clarification.
    I have probably not understood the use of table_model completely even after reading the verilogAMS reference manual,
    If you could clarify on the following doubts:-
    a)
    Suppose I have a file (named test.txt) with three columns. The first two columns are independent variables and the third one is the dependent variable.
    I need linear interpolation. So can I write as follows for verilogAMS:-
    Y=$table_model(vx,vy, "test.txt", "1L,1L;1")        (vx and vy are my independent variables in the code)
    Andrew Beckett over 5 years ago in reply to RFStuff
    Yes, that looks reasonable.
