  3. Importing corner setup from CSV with double quotes
  • Views 14919
Mike Bichan
Mike Bichan over 5 years ago
I would like to import my "corner setup" into ADE Assembler from a CSV file.
One of the variables defined is a file name that needs to be specified with double quotes or Cadence/Spectre will not run.
In normal CSV files, double quotes are included by escaping them with a second double quote.
However, importing the corner setup from CSV doesn't like it whether I use one, two, or three double quotes.
Is there a way to import a corner setup from CSV that supports double quotes?
This is the error I get:
ERROR (ASSEMBLER-2053): Cannot import data from the CSV file '/path/to/file/corners_test.csv' because the quotation marks used in row 8 are invalid. Ensure that the quotation marks used to enclose string values are specified in pairs. To use a quotation mark as part of a string value, enclose the string value by a pair of quotation marks and replace the quotation mark within the string with two consecutive quotation marks.
    I just tried it by doing this (I created it by hand in the UI and exported it, and then was able to import it):
    Corner,C0
    Enable,t
    Temperature,30
    MYSPFILE,"""file2.s2p"",""file3.s2p"""
    t Test::mylib_forumCSV_1,t
    That worked fine (in IC6.1.8.500.14)
  • Mike Bichan
    Mike Bichan over 5 years ago in reply to Andrew Beckett
    Ok thanks for checking Andrew.  I am using ICADV12.3-64b.500.22.  I'm not familiar with the version numbers, maybe this is older?
    Andrew Beckett over 5 years ago in reply to Mike Bichan
    Hi Mike,
    I didn't have that precise advanced node release, but that's equivalent (from ADE - identical in fact) to IC6.1.7 ISR22. I tried it there and it worked fine (with the CSV I showed above). Perhaps you could share the CSV you tried to use?
  • Mike Bichan
    Thanks for your response.  Your CSV filed worked fine.  It turned out the problem was that I had created the CSV file in Excel in windows.  Once I ran dos2unix on the CSV file it now is imported without problem into the corner setup. There were some differences in non-printing characters that may have been causing the problem.
    -Mike
