  3. csh C script for automating the ocean simulation
  • Replies 14
  • Views 20059
Aksh
Aksh over 5 years ago
Dear all,
I am trying to build a C script that sets the environment, invokes the ocean software and completes the simulation without any interventions required. (basically automating the whole simulation).
In the bigger picture, I want simulations to be invoked by MATLAB and I want the simulations to be performed in inputs varying iteratively (given by a Matlab algorithm).
The C script looks something like this:
csh
source /home/install/cshrc
ocean
load("test.ocn")
The problem is that the commands up to the line "ocean" work beautifully.
But I am not able to run the "load" command and is the reason I am not able to complete the simulation.
After some searching, I found that the "load" command can be placed in a .oceanrc file. But I am not sure it will work and also I am not able to find its directory nor have any idea where to place it.
Can anyone suggest a method so that I can complete this script?
Any leads are highly appreciated.
Thank You
Aksh Chordia
  • Aksh
    Aksh over 5 years ago in reply to ShawnLogan
    Thanks for your insight Shawn and Andrew.
    But I am a newbie to the world of cadence and csh scripting.
    My basic question is: what can I can to make the script work? (either basically make the script readable after the ocean command or by doing something else)
  • Aksh
    Gotcha!
    Thanks, it works, the directory was changing.
    Thank You so much for your time and efforts.
    Cheers
    Aksh
  • Aksh
    Aksh over 5 years ago in reply to Andrew Beckett
    Yes, this is exactly what I am looking for: how to pass the arguments through the wrapper scripts?
    Though the -restore works, I was missing the directory path.
    Thank You very much for your time and efforts.
    Cheers
    Aksh
    ShawnLogan over 5 years ago in reply to Aksh
    Dear Aksh,
    Great! Thank you for letting us know!
    Shawn
