  3. csh C script for automating the ocean simulation
  • Replies 14
  • Views 20058
Aksh
Aksh over 5 years ago
Dear all,
I am trying to build a C script that sets the environment, invokes the ocean software and completes the simulation without any interventions required. (basically automating the whole simulation).
In the bigger picture, I want simulations to be invoked by MATLAB and I want the simulations to be performed in inputs varying iteratively (given by a Matlab algorithm).
The C script looks something like this:
csh
source /home/install/cshrc
ocean
load("test.ocn")
The problem is that the commands up to the line "ocean" work beautifully.
But I am not able to run the "load" command and is the reason I am not able to complete the simulation.
After some searching, I found that the "load" command can be placed in a .oceanrc file. But I am not sure it will work and also I am not able to find its directory nor have any idea where to place it.
Can anyone suggest a method so that I can complete this script?
Any leads are highly appreciated.
Thank You
Aksh Chordia
    ShawnLogan over 5 years ago
    Dear Aksh,
    I believe the default location for your .oceanrc command is your $HOME directory. Its contents will be executed when ocean is invoked from the UNIX command line. In my case, I want the same variables set as when I launch a Cadence session. Hence, the contents of my ~/.oceanrc file is:
    "load("~/.cdsinit")"
    However, if your objective is to load the file "test.ocn", if the file "test.ocn" is in the same directory from which you are starting ocean, is there a reason you did not use the command:
    ocean -nograph < test.ocn > run_test.out
    This will load the file "test.ocn" and writes the output to a new file "run_test.out" and assumes no plotting is requried (-nograph option).
    An alternative command is included in the reference article:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nVZuEAM&pageName=ArticleContent
    Does this help Aksh?
    Shawn
    I personally tend to recommend using "ocean -restore test.ocn" rather than redirecting the input. This has the benefit of becoming an interactive session at the end - if you don't want that, you can always finish your OCEAN script with an exit() call.
    ShawnLogan over 5 years ago in reply to Andrew Beckett
    Dear Andrew,
    For my education, if I may, is your preference for using the "-restore" option based on the potential for an ocean buffer overflow? If you are busy, I fully understand and can bury my question!
    Shawn
    Partly that, but mostly due to the fact that the behaviour with non-blocking elements can be different, and also that you don't get a return value per input line appearing in the output log. Using -restore is exactly like running virtuoso and then doing load() afterwards, whereas redirecting the input is just like typing everything in at the prompt.
  • Aksh
    Aksh over 5 years ago in reply to Andrew Beckett
    Will this work even in a csh script?
    Dear Andrew,
    Thank you for the added insight...and once again...your time and patience!
    Shawn
  • Aksh
    I tried by placing the command the command: in the csh script
    But all it does again is open the ocean command line and not loading the test.ocn file.
    ShawnLogan over 5 years ago in reply to Aksh
    Dear Aksh,
    As long as you keep in mind that invoking "csh" opens a new shell...
    Shawn
    ShawnLogan over 5 years ago in reply to ShawnLogan
    Dear Aksh,
    Did you try providing the full directory path to the file "test.ocn" as the argument to ocean? As I noted, csh will open a new shell.
    Shawn
    Andrew Beckett over 5 years ago in reply to Aksh
    Maybe you have wrapper scripts in your environment (and so you're not invoking directly the "ocean" from an IC installation; typing "which ocean" will tell you that), and those wrapper scripts are not passing the arguments through?
    The -restore option has been supported for as long as I can remember.
