  3. scaling layout
  • Views 15982
scaling layout
MReza Mah
MReza Mah over 5 years ago
Guys, is there any way to scale a design (layout)? For example, let's say I have a design that includes only metal-1 and I want to scale it both in x and y directions, by a factor of 0.9. Any solution on how to do this, preferably using Virtuoso? Appreciate it.
    You can use the "XScale" utility from the UNIX command line (running that without arguments will tell you how to use it).
