  3. Simulating a DAC in Cadence
  • Views 17464
mirtaji65
mirtaji65 over 5 years ago
hi
I am trying to simulate a 8-bit DAC in Cadence I want to input all digitial input combinations from 00000000 to 11111111 (0 to 256) incrementing by 1 each time and also I can also hold it on a specific output to test the circuit. The problem is that is it not very  feasible to set these inputs using 8 vpulse function
how can i solve this problem
thanks
    You could use an 8-bit ideal ADC from ahdlLib and then ramp the input (adc_8bit_ideal would do the job). Andrew.
  • mirtaji65
    mirtaji65 over 5 years ago in reply to Andrew Beckett
    Thank you,
    that's what I was looking for it
