  3. deepprobe gives error when probing: --- WARNING (SPECTRE...
  • Views 2723
deepprobe gives error when probing: --- WARNING (SPECTRE-8281): `p0' is not a node nor an instance name.
Mike Bichan
Mike Bichan over 5 years ago
I am instaniating an analogLib/deepprobe instance at the top level of my schematic to allow probing inside an extracted netlist.
This instance shows up like this in the netlist:
IPRB2 (xcdr_vco.xvco_biasvosc.xosc.XOSCHI_Xosc_Xbfr1_XBFRP_MN0_GATE n0) iprobe
I am also saving the voltage like this:
save n0
For some reason, I get these warnings in the output file:
WARNING (SPECTRE-8281): `n0' is not a node nor an instance name.
WARNING (SPECTRE-8286): Ignoring invalid item `n0' in save statement.
And the voltage waveform on n0 is not saved during the simulation.
Am I doing something wrong here? Is there a better way to probe a net inside an extraction. My ultimate goal is to run PSS simulation and set the "oscillator node" to an internal node of an extracted netlist. But the PSS dialog box doesn't allow you to type in a hierarchical net name, it must be something present in the schematic.
  • Mike Bichan
    Never mind, I realized that my hierarchical net name should not have used "x" before each hierarchy level.  So that net was floating and was getting pruned, therefore it was not available to be probed/saved.
