  3. How can I change several tests on Assembler simultaneously...
  • Views 14717
How can I change several tests on Assembler simultaneously?
BillH314
BillH314 over 5 years ago
If I have an Assembler maestro setup with several sub-tests and I want to make the same change to all of the sub-tests how would I do that?
E.g. say I want to change the model files used, or change the outputs saved, or the simulator settings and have that change common to several tests.
With the old ADE-XL I could just make the changes in one test, save the state, then load that state onto the other tests.   But since there's no states anymore I don't see how to do that with Assembler.
I'm still getting used to the L/XL -> Explorer / Assembler change.
Thank you,
Bill Huff
    Hi Bill,
    You can use the Multi-Test Editor to do this (in IC618 - from an early ISR - I think it was added in ISR3 or 4 if I remember rightly). Tools->Multi-Test Editor.
    You can also descend into the test, and then do Session->Import to import from another test (possibly in another view). However, the multi-test editor is more finegrained than the import, and helps you compare the settings across multiple tests, and potentially copy them (e.g. just unify the stop time of a transient across all your tests, but leave everything else the same).
  • BillH314
    BillH314 over 5 years ago in reply to Andrew Beckett
    Thank you Andrew
    I see now - with the import I can basically do the equivalent of loading the "state" from any test in any history in any other maestro assembler views.
    Thank you,
    Bill Huff
