  3. [AWR Microwave Office] Issue related to plot of contour...
  • Views 13748
[AWR Microwave Office] Issue related to plot of contours
Eres
Eres over 5 years ago
Dear All,
I've quite big problem related to contours in AWR. I can generate LP_Data file of an amplifier from load-pull analysis implemented in AWR. Moreover, I can plote parameters such as PAE, Gain, etc. from load point of view, for particulat input gamma points. However, when I want to plot results for input - source side (for particular gamma loads points) I receive error: Measurement - LP_Data:G_LPCM_EX(G_Power,0.5,5,50,0)[8,1,X] : Unable to compute G_LPCM_EX measurement. Moreover, only "plot all traces" option is working, however I see then every single solution, for all gamma input points:
The error above is related to other parameter in which I want to change gamma of source (by using a marker on different plot). As you can see, this is quite...unreadable. This is AWR issue ? Can it be my mistake ? I use AWR 12, 14 and 15 - and in all version I see errors but with different cause (for 12 is related to not defined sweep, for 15 is related to license - I use student versions from University).
Best Regards,
E.
