  3. ERROR EMX in virtuoso
  • Views 18382
tawsaras
tawsaras over 5 years ago
I am trying to simulate an inductor in EMX.
I am getting following error:-
*Error* hiGetTextWidth: argument #1 should be a string (type template = "t") - text
Please help me with this.
    Andrew Beckett over 5 years ago in reply to tawsaras +1
    OK, that's also still pretty old and it appears that the EMX code doesn't quite handle that version (I'll mention this to R&D). However, I think you can fix it fairly easily. In the INTEGRAND20 installation…
    Which version of EMX are you using? Also would be useful to know which IC subversion you're using too (Help->About)?
    This might be an issue in your EMX config file - but let's start at least with the versions used...
  • tawsaras
    tawsaras over 5 years ago in reply to Andrew Beckett
    Hi Andrew
    I am using IC6.1.1-64b.500.11 and Integrand 10.02
    I'm assuming you're not really using IC6.1.1 - that's ancient (probably 12-13 years old). Can you check? Integrand 10.02 is pretty new.
    Can you also try doing:
    _stacktrace=50
    and reproducing the error - this might give a bit more insight. This would probably be best handled via customer support so that we can see what's going on...
  • tawsaras
    Sorry It was IC6.1.6.
  • tawsaras
    tawsaras over 5 years ago in reply to tawsaras
    I tried _stacktrace=50 and get the following message
    <<< Stack Trace >>>
    hiGetTextWidth('text "This is a line of text that should fit completely within the width of the window")
    max(hiGetTextWidth('text "This is a line of text that should fit completely within the width of the window") 250)
    min(max(hiGetTextWidth('text "This is a line of text that should fit completely within the width of the window") 250) 500)
    min(min(max(hiGetTextWidth(& "This is a line of text that should fit completely within the width of the window") 250) 500) (max_screen_x / 2))
    (desired_width = min(min(max(& 250) 500) (max_screen_x / 2)))
    _ilSeqArgs((screen_coords = hiGetMaxScreenCoords()) (max_screen_x = car(screen_coords)) (max_screen_y = cadr(screen_coords)) (desired_width = min(min(& 500) (max_screen_x / 2))) (desired_height = min((40 * &) (max_screen_y / 2))) ... )
    letseq(((screen_coords hiGetMaxScreenCoords()) (max_screen_x car(screen_coords)) (max_screen_y cadr(screen_coords)) (desired_width min(& &)) (desired_height min(& &)) ... ) list((ll_x:ll_y) ((ll_x + desired_width):(ll_y + desired_height))))
    EMX_log_window_geometry((job->bgui) (job->id))
    view((job->log_file) EMX_log_window_geometry((job->bgui) (job->id)) (job->log_title) t)
    (job->log_viewer = view((job->log_file) EMX_log_window_geometry((job->bgui) (job->id)) (job->log_title) t))
    if(EMX_log_displayer ipcBatchProcess(sprintf(nil EMX_log_displayer (job->log_file)) "" "/dev/null") (job->log_viewer = view((job->log_file) EMX_log_window_geometry(& &) (job->log_title) t)))
    when(((job->log_file) && isFile((job->log_file))) if(EMX_log_displayer ipcBatchProcess(sprintf(nil EMX_log_displayer &) "" "/dev/null") (job->log_viewer = view(& & & t))))
    EMX_display_log(job)
    if(isFile((job->log_file)) EMX_display_log(job) EMX_informational("Log file slow to appear, skipping display.\nTry clicking the 'Status' button in a bit..."))
    let(((job car(&)) (acceptor lambda(& nil))) (bgui->pending_jobs = cdr((bgui->pending_jobs))) when(EMX_debug_shell_commands printf("EMX Virtuoso interface job %d starts:\n%s\n" (job->id) (job->what))) deleteFile((job->log_file)) (bgui->active_jobs = ((bgui->active_jobs) + 1)) ... )
    while(((bgui->pending_jobs) && ((bgui->active_jobs) < EMX_job_limit)) let(((job &) (acceptor &)) (bgui->pending_jobs = cdr(&)) when(EMX_debug_shell_commands printf("EMX Virtuoso interface job %d starts:\n%s\n" & &)) deleteFile((job->log_file)) (bgui->active_jobs = (& + 1)) ... ))
    let((any_started) while(((bgui->pending_jobs) && (& < EMX_job_limit)) let((& &) (bgui->pending_jobs = &) when(EMX_debug_shell_commands &) deleteFile(&) (bgui->active_jobs = &) ... )) any_started)
    EMX_start_jobs(bgui)
    let(((job make_EMX_job(?bgui bgui ?id & ?cid ... ))) (bgui->next_job_id = ((bgui->next_job_id) + 1)) ((bgui->jobs)[work_dir] = job) (bgui->pending_jobs = append((bgui->pending_jobs) list(job))) EMX_start_jobs(bgui))
    EMX_submit_job(bgui work cmd sprintf(nil "EMX status: %s %s" (bgui->Library) (bgui->Cell)))
    let(((cmd EMX_wrap_for_remote(bgui & nil nil))) EMX_submit_job(bgui work cmd sprintf(nil "EMX status: %s %s" (bgui->Library) (bgui->Cell))))
    let(((work EMX_work_dir(bgui))) construct_EMX_command(bgui gds_file gds_dir EMX_gds_top_cell(bgui)) let(((cmd &)) EMX_submit_job(bgui work cmd sprintf(nil "EMX status: %s %s" & &))))
    funcall(fn)
    EMX_with_case("" '(nil) 1 what)
    if(EMX_use_case_name let(((cases &) (msgs &)) when((& && & && names_only) EMX_error("Multiple cases are not allowed for %s\nwhen defaults are not configured" names_only)) do((&) (&) letseq(& &)) letseq((& & & &) when(& &) when(& &) when(& &))) EMX_with_case("" '(nil) 1 what))
    EMX_cases_do(bgui lambda(nil let((&) construct_EMX_command(bgui gds_file gds_dir &) let(& &))) "simulations")
    letseq(((gds_info stream_out_for_EMX(bgui)) (gds_file nth(0 gds_info)) (gds_dir nth(1 gds_info))) EMX_maybe_set_win_geom_base_id(bgui) EMX_cases_do(bgui lambda(nil let(& & &)) "simulations") EMX_maybe_show_pending(bgui))
    letseq(((bgui EMX_basic_gui()) (xx EMX_advanced_gui(bgui))) EMX_check_executable(bgui "emx" "EMX") EMX_check_directory_conflicts(bgui) letseq(((gds_info &) (gds_file &) (gds_dir &)) EMX_maybe_set_win_geom_base_id(bgui) EMX_cases_do(bgui lambda(nil &) "simulations") EMX_maybe_show_pending(bgui)))
    start_EMX()
    hiDisplayForm(create_EMX_gui(for_schematic_view for_calibre_view))
    show_EMX_gui(nil nil)
    OK, that's also still pretty old and it appears that the EMX code doesn't quite handle that version (I'll mention this to R&D). However, I think you can fix it fairly easily. In the INTEGRAND20 installation you'll have this file:
    virtuoso_ui/emxinterface/emxskill/emxform.ils
    Edit this file, and find the call to hiGetTextWidth (within the function EMX_log_window_geometry). Change the first argument from 'text to "text" and that should fix it. However, it will hit another problem in the same function - so you'll need to change the hiQueryFont line too. The two (three) lines after changing are:
    (desired_width (min (min (max (hiGetTextWidth "text" "This is a line of text that should fit completely within the width of the window") 250) 500)
        max_screen_x/2))
    (desired_height (min 40*(hiQueryFont "text")->fontHeight max_screen_y/2))
    I would strongly recommend moving to IC6.1.7 or IC6.1.8.
