  3. Variable set in corners overrides variable locally defined...
  • Views 15022
Variable set in corners overrides variable locally defined in test
SteveDobbs
SteveDobbs over 5 years ago
Cadence_icadvm v18.10.130
ADE Assembler
I am running a trimming (calibration) simulation. The trimming must be done at a fixed supply voltage. Thereafter, I want the post-trim test to take the value set in the corners for the supply voltage.
In the trim test, I set the supply voltage to the desired trimming value LOCALLY i.e. vsup=vsupTrim where vsupTrim is a global variable with a fixed value.
In the corners, vsup has a range of values.
When I run the two tests together across corners, the trimming test simply picks up the value for vsup defined in the corners, ignoring the local override.
I have tried setting the local variable, vsup=VAR("vsupTrim") and also avoiding the global altogether i.e. vsup=3, but neither works.
I appreciate that this may be expected behaviour but is there a workaround to achieve a constant supply voltage for the trim test even though the corners want to vary this variable
Note: A similar approach for temperature seem to work OK i.e. ....
trim test:   temperature = VAR("trimTemp") with trimTemp set as a global
2nd test:  temperature = VAR("simTemp")  with simTemp varied across corners
Temperature in the trim test is not varied across corners in this case.
  • SteveDobbs
    Found a solution .....
    Make vsup (which is the variable on the supply voltage source in the schematic) constant during trim.
    Create new global variable, simVsup.
    Set vsup=simVsup locally in all post-trim tests.
    Make simVsup vary across corners
    Result; supply voltage is constant during trim test (independent of corners). Supply voltage varies across corners for post-trim tests.
    This is actually the reverse of what I tried to do initially, and seems to work.
    Andrew Beckett over 5 years ago in reply to SteveDobbs
    Steve,
    Something doesn't sound right here - I think what you describe originally sounds as if it should work (if I've understood properly). Perhaps you could contact customer support so that we could have one of the team look at it?
  • SteveDobbs
    SteveDobbs over 5 years ago in reply to Andrew Beckett
    Case submitted (#46490862) with you on copy.
    Steve
    Hi Steve,
    Thanks - I've got one of my team to look at this (I'm a bit tied up myself with other stuff for the company you work for today...)
