  3. CALCULATOR DNL/ INL DAC
  • Replies 14
  • Views 45934
mirtaji65
mirtaji65 over 5 years ago
Hi
I'm designing a 4 bit DAC.I have completed the schematic and The output waveform of the block is as follows
I want measure INL error and I use INL function in calculator I try this expression
dnl(v("/net055" ?result "tran") 6.251e-5  ?mode "auto"  ?crossType "rising" ?delay 0.0 ?method "end" ?units "abs" ?nbsamples 16)
and it could't It does not work properly  the output waveform is as follows
Where is the problem?
 is my method to use this function currect ?
THANKS
    ShawnLogan over 5 years ago in reply to mirtaji65 +1
    Dear mirtaji65, I am confused. 1. You changed the function applied to /net055 from the dnl() function to the inl() function? The dnl() and in() functions provide different results. I thought you wanted…
  • mirtaji65
    mirtaji65 over 5 years ago in reply to ShawnLogan
    I made a waveform for testing
    The result of the dnl function is as follows
    Which is the X-axis and the Y-axis are in terms of voltage
    The result of the dnl function in mathlab is as follows
    Which is the X-axis in terms of time and the Y-axis are in terms of voltage
    As is clear from the signal of the value (0v to 1.8v) after that (1.8v to 0v) after that (0 to 3.2)
    And because one axis is in terms of voltage and the other is time, the waveform is not the same.
    you can't use the YvsY() function
    i use dc signal 0v as the time axis as a waveform (/net011)
    when i plot two out put in simulation Draws them in the subwindows form
    I can use YvsY for (/net11) and (/net05)  Because both of the in same windows and choose select trace
    i can not plot inl and (/net11) in same window that YvsY
    What should I do to solve the problem?
    In your opinion, it is not better to write a program VHDL or verilog
    Dear mirtaji65,
    I hope the following solves your latest problem. I have included the specific steps I followed and the resulting plots of INL versus voltage and the new plot of INL versus Time.
    Shawn
    Fullscreen example_plot_inl_vs_time.txt Download
    1. Create time values:
    value(v("/vout" ?result "tran") 0.5e-06  ?period 1e-06 ?xName "time"  )
    Place in Calculator Table (Tools->Table)
    2. Create inl values:
    value(inl(v("/vout" ?result "tran") 1e-06  ?mode "auto"  ?crossType "rising" ?delay 0.5e-06 ?units "abs" ?nbsamples nil) 0.5e-06 ?period 1e-06 ?xName "time")
    Append to table (See below for comma-separated variable file I created)
    3. Save table as a comma-separated variable file with <filename> (i.e. nl_xval_inl.csv)
    3.Create new waveform:
    getAsciiWave("Full path to saved file inl_xval_inl.csv"> 1 4 ?xskip 1 ?yskip 1 ?formatFloat nil ?xName "Time" ?xUnits "sec" ?yName "inl" ?yUnits "LSB" )
    4. Plot new waveform
    5. Enjoy!
    Example "inl_xval_inl.csv"
    time (s),xval(value(v("/vout" ?result "tran") 0.5e-06  ?period 1e-06 ?xName "time"  )) (s),V (V),inl
    500.00000E-9,500.00000E-9,24.961888E-3,0.0000000
    1.5000000E-6,1.5000000E-6,72.934183E-3,-37.478530E-3
    2.5000000E-6,2.5000000E-6,123.74225E-3,-18.059857E-3
    3.5000000E-6,3.5000000E-6,175.35193E-3,17.442537E-3
    4.5000000E-6,4.5000000E-6,223.30014E-3,-20.519130E-3
    5.5000000E-6,5.5000000E-6,276.42237E-3,45.331194E-3
    6.5000000E-6,6.5000000E-6,323.72824E-3,-5.5186424E-3
    7.5000000E-6,7.5000000E-6,374.44416E-3,12.051288E-3
    8.5000000E-6,8.5000000E-6,425.94798E-3,45.429609E-3
    9.5000000E-6,9.5000000E-6,474.45422E-3,18.664130E-3
    10.500000E-6,10.500000E-6,524.10157E-3,14.794140E-3
    11.500000E-6,11.500000E-6,576.87473E-3,73.640760E-3
    12.500000E-6,12.500000E-6,622.86814E-3,-3.5422922E-3
    13.500000E-6,13.500000E-6,675.23440E-3,47.140060E-3
    14.500000E-6,14.500000E-6,722.63109E-3,-1.8875072E-3
    15.500000E-6,15.500000E-6,772.56539E-3,-555.11151E-18
    sml 1/4/2021
  • mirtaji65
    Dear Shawnlogan
    Your solution for converting X-axis from voltage to time works exactly.
    But why do I have to sample the waveform by use <<value function>>  when i want to use INL and DNL function ,why delay of INL function doesn't work itself,
    Is this a software bug?
    ver virtuoso :6.17.77
    This method is not suitable if I want to use the analysis parameter
    But your method of  converting X-axis from voltage to time  was great
    thanks my friend
    Dear mirtaji65,
    Great! Thank you for letting us know!
    First, I do not work for Cadence and hence cannot really respond to your comment about the behavior of INL. However, the INL function, as it is documented, does not provide the x-axis as a function of time (which is what I assume you want). Hence, the "workaround" using the value() function.
    Sorry, I don't understand exactly what you mean by this comment! You can use this methodology in an Explorer/Assembler expression through the use of an ocean script. This is documented at URL:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nXTvEAM&pageName=ArticleContent
    and
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nXS2EAM&pageName=ArticleContent
    Hence, you may define the steps in an ocean script and add the ocean script as an Explorer/Assembler output.
    I hope this helps mirtaji65,
    Shawn
