  3. ams XCELIUM simulation pauses
  • Replies 7
  • Views 16006
Michael H
Michael H over 5 years ago
we encounter the following issue in a mixed signal simulation using the following tools:
IC6.1.8-64b.500.15
XCELIUM 19.09-s010
SPECTRE 18.1.0.556.isr13 64bit not sure if the spectre version is bound to the XCELIUM release anyway
The simulation "pauses" after a few hours runtime. The xmsim process is not consuming any cpu power anymore and is in "S" state. The simulation log does not show anything unnormal - it's just not updating anymore. Now the strange thing: it is possible to get the process back to live by sending a kill signale - SIGUSR1 - to the process. The simulation just proceeds and eventually stops after a few hours again.
It does not matter if the simulation is running as a local simulation or via SGE on a cluster configuration.
Michael
    Michael,
    That seems a bit odd. Please contact customer support.
  • Michael H
    Michael H over 5 years ago in reply to Andrew Beckett
    Thanks Andrew,
    I opened a support ticket.
    Michael
  • amifsud
    amifsud over 4 years ago in reply to Michael H
    Hi Michael,
    Apart from the solution above, did you find a more stable solution? I am experiencing the same issue.
    Thank you!
    Andrea
  • Michael H
    Michael H over 4 years ago in reply to amifsud
    Dear Andrea,
    I can't fully remember how things got solved in the end. Actually it worked to use a newer SPECTRE version, by enabling "Enable AMS flexible release matrix" in the Netlist and Run Options. With this option  the SPECTRE version is independent of the XCELIUM version. Instead of SPECTRE18 we used a later hotfix version of SPECTRE19, the error did not show up again.
    Michael
    Andrew Beckett over 4 years ago in reply to Michael H
    Michael,
    I found the CCR for your case (2419270) and see it recorded there that you'd tried (at the end of January this year) the latest XCELIUM2003 hotfix in flex mode and I think it was using the latest SPECTRE19.1 hotfix too - and that worked. Certainly using flex mode solved it in these cases (and only flex mode is supported now anyway).
  • Michael H
    Michael H over 4 years ago in reply to Andrew Beckett
    thank you for looking this up. Yes, back then I tried a few different combinations and in the end the newest SPECTRE19.1 hotfix solved it. It does work with the old XCELIUM19.09 release in flex mode as well.
    Michael
  • amifsud
    Hi Both,
    Just wanted to thank you for your replies!
    Simulation has been running without pausing for a good number of hours after enabling AMS flex.
    Best regards,
    Andrea
