  3. Rise & fall time of a periodic signal
  • Replies 19
  • Views 13130
sidm
sidm over 5 years ago
Hi All,
i am sweeping capacitance being driven by a signal in my testbench to see the impact of the capacitor. The signal is a periodic one as shown below from 0 to 1.8v
Is there a way I can get the raise & fall time of the signal plot against the swept capacitance ?
The signal gets skewed as the driving capacitance increases.
thanks
    Andrew Beckett over 5 years ago in reply to sidm
    I've not seen reports of this happening, but anyway you should be moving to using Explorer instead which has a different sweep mechanism,
    ShawnLogan over 5 years ago in reply to Andrew Beckett
    Dear sidm,
    I agree with Andrew regarding your use of Explorer or Assembler.
    However, you are making debugging a bit difficult as you haven't uploaded the spectre.out file nor answered my question regarding whether you submitted this parametric analysis to your interactive machine or whether you submitted it to an LSF farm (i.e. a distributed analysis). I am wondering if you did the latter there was a communication issue between your session and the machine on which the last iteration was performed. In that case, the spectre.out file would show the simulation completed, but the job completion notice may not have been communicated properly to the Parametric tool.
    Shawn
  • sidm
    sidm over 5 years ago in reply to ShawnLogan
    thanks Shawn, I am not using LSF.
    The log ends something like the following :
    During simulation, the CPU load for active processors is :
            Spectre  0 (84.3 %)      1 (85.9 %)      2 (85.1 %)      3 (85.6 %)
                     4 (85.2 %)      5 (85.7 %)      6 (86.1 %)      7 (85.3 %)
            Other
    Initial condition solution time: CPU = 253.087 s, elapsed = 42.5773 s.
    Intrinsic tran analysis time:    CPU = 16.8409 ks, elapsed = 2.82258 ks.
    ************ AHDL Lint Summary ************
    Number of accepted steps = 14548
    #Steps Type         Instance:File:Line No.
     14397 contribution I0.mipitx.R4.r1:Internal (bsource):0
    Total time required for tran analysis `tran': CPU = 17.0943 ks (4h 44m 54s), elapsed = 2.86543 ks (47m  45.4s).
    Time accumulated: CPU = 17.1164 ks (4h 45m 16s), elapsed = 2.89933 ks (48m  19.3s).
    Peak resident memory used = 2.44 Gbytes.
    Notice from spectre.
        1116 notices suppressed.
        4005637 warnings suppressed.
    finalTimeOP: writing operating point information to rawfile.
    Opening the PSF file ../psf/finalTimeOP.info ...
    Warning from spectre during info `finalTimeOP'.
        WARNING (ASL-6233): "Internal (bsource)" 0:  I0.mipitx.R4.r1:  The value 0.0004757 has been clamped to 0.001. Set parameter 'rclamp' to change the clamped value if the value is within the permissible limit.
    modelParameter: writing model parameter values to rawfile.
    Opening the PSF file ../psf/modelParameter.info ...
    element: writing instance parameter values to rawfile.
    Opening the PSF file ../psf/element.info ...
    outputParameter: writing output parameter values to rawfile.
    Opening the PSF file ../psf/outputParameter.info ...
    designParamVals: writing netlist parameters to rawfile.
    Opening the PSFASCII file ../psf/designParamVals.info ...
    primitives: writing primitives to rawfile.
    Opening the PSFASCII file ../psf/primitives.info.primitives ...
    subckts: writing subcircuits to rawfile.
    Opening the PSFASCII file ../psf/subckts.info.subckts ...
    Post-Simulation Summary
                    Analysis        Analysis ID        CPU (s)      Elapsed (s)
             1          tran              tran        1.71e+04        2.87e+03
             2          info        finalTimeOP       1.20e+00        1.20e+00
             3          info        modelParameter    1.23e-01        1.24e-01
             4          info           element        1.36e+00        1.36e+00
             5          info        outputParameter   1.16e+00        1.16e+00
             6          info        designParamVals   1.50e-01        1.50e-01
             7          info        primitives        6.07e-02        6.18e-02
             8          info           subckts        7.87e-02        8.01e-02
         Total                                        1.71e+04        2.87e+03
       Average                                        2.14e+03        3.59e+02
    Elapsed Min         info        primitives        6.07e-02        6.18e-02
    Elapsed Max         tran              tran        1.71e+04        2.87e+03
    Aggregate audit (12:47:56 AM, Thur Dec 24, 2020):
    Time used: CPU = 17.1 ks (4h 45m 23s), elapsed = 2.91 ks (48m  27.0s), util. = 589%.
    Time spent in licensing: elapsed = 66.8 ms.
    Peak memory used = 2.44 Gbytes.
    Simulation started at: 11:59:29 PM, Wed Dec 23, 2020, ended at: 12:47:56 AM, Thur Dec 24, 2020, with elapsed time (wall clock): 2.91 ks (48m  27.0s).
    spectre completes with 0 errors, 61 warnings, and 27 notices.
    ShawnLogan over 5 years ago in reply to sidm
    Dear sidm,
    sidm said:
    I am not using LSF.
    Thank you sidm!
    From your comments, it appears my hypothesis concerning a communication issue between the Parametric tool and LSF is not correct. Based on your uploaded spectre.out file, my thought is now that the "progress bar" is not complete as ADE-L is attempting to compute your added ADE-L output expressions for transition times.
    1. If you are sweeping the capacitance, I am assuming your last analysis is performed with the capacitance at its maximum value. Is this correct?
    2. If it is at the maximum capacitance, are you sure the output waveform is crossing the minimum and maximum thresholds you set for computing the transition times under this maximum capacitance value?
    3. Perhaps if you:
    a. Disable the added ADE-L expressions for transition times and then run the Parametric analysis, does the simulation complete and the progress bar indicate 100%?
    b. Examine the waveforms in ViVA to validate that all cross the minimum and maximum thresholds you set in the rise/fall time expressions.
    c. Enable the transition time ADE-L expressions for plotting
    d. Plot (do not re-simulate) the expressions after selecting the Parametric results by using the ADE-L plot button (beneath the "Stop" simulation button).
    Shawn
  • sidm
    Hi Shawn,
    Yes the last analysis is performed with the capacitance at its maximum value.
    Yes at the maximum capacitance the output waveform is crossing the minimum and maximum thresholds.
    I will try to Disable the added ADE-L expressions for transition times and then run the Parametric analysis,
    Please upload the entire spectre.out file (don't just paste it, use Insert->Image/Video/File from the insert link below; you might need to rename the file with a .txt suffix), ideally running with diagnose enabled. I'd like to get an idea about how long each point in the sweep takes, and if there are any issues with the last point. The excerpt you posted above wasn't enough to determine much, and it may be that this is an update problem with ADE L, and the simulation itself ran fine. Or it might be a genuine simulation problem, and the enhanced log file might give a clue.
    Thanks.
  • sidm
    sidm over 5 years ago in reply to Andrew Beckett
    thanks for checking this Andrew.  I am checking internally so that I can upload the .out file.
    One more thing that I observe is that the operating system is CentOS , not sure if that can be a cause of the problem.
    I doubt that CentOS would have anything to do with this. I can’t really see how it could, at least.
  • sidm
    thanks for the reply Andrew.  I tried a simpler testcase and observed that parametric simulation went through for it with the progress bar going to 100%.
