  3. Running checkSysConf Successfully for AMS tool.
  • Views 14793
RFStuff
RFStuff over 5 years ago
Dear All,
I was able to run checkSysconf for IC618 and MMSIM18.
This pointed me to the uninstalled required patches. After I installed all these patches, checkSysConf gave PASS for both IC618 and MMSIM18.
But, when I tried to run checkSysconf for INCISIVE152, I got following errors. It DOES NOT give me the Valid Release name for AMS tool.
I wonder why it is happening for AMS tool only.
Is there anyway, checkSysConf can allow me to tell the needed uninstalled packages for AMS tool like IC618 and MMSIM18.
Kind Regards,
[Copyright 2002-2011] Cadence Design Systems, Inc. All rights reserved.
This program and online documentation may not be copied, modified,
re-published, uploaded, executed, or distributed in any way, in any
medium, whether in whole or in part, without prior written permission
from Cadence Design Systems, Inc.
============== checkSysConf: Version 3.19 ====================
Configuration checks failed on this workstation (hp), status is: FAIL
checkSysConf cannot reliably parse your systems /etc/redhat-release file
It would appear that the file is non-standard and does not contain release
information in the standard readable format.
The contents of your /etc/redhat-release is listed below between
<RELEASE_FILE> tags.
A 'correct' release file should have only one line of content, containing
version information in a standard format.
<RELEASE_FILE>
CentOS Linux release 7.9.2009 (Core)
</RELEASE_FILE>
Please check/correct your /etc/redhat-release file and try again.
There is no OEM datafile for -r for the Linux platform.
Valid OEM images are :
foreach: No match.
    INCISIVE152 was never supported on RedHat Enterprise 7.X releases (i.e. it was not tested or released on that platform), and certainly not CentOS equivalents (the checks have become more tolerant of CentOS recently). Even on my RHEL7.6 machine I get:
    Configuration checks failed on this workstation (lnx-andrewb-76), status is: FAIL
    <RELEASE_FILE>
    Red Hat Enterprise Linux Workstation release 7.6 (Maipo)
    </RELEASE_FILE>
    RHEL7 was pretty new at the time that INCISIVE152 was released, and so it was not part of our platform matrix in place at the time of release. IC617 did make it into RHEL7 support, but INCISIVE152 didn't.
    This is also clear if you look on http://downloads.cadence.com for INCISIVE152, you'll see that it doesn't list RHEL7.
    That said, I'm sure it should just run - and if there are any shared libraries missing, it is likely to be clear when running the simulation as it would fail. The right thing (as in another post) is to move to XCELIUM rather than using this old release on a current OS.
