  3. dbOpenCellViewByType: Corrupted database encountered:
  • Subscribers 126
  • Views 14547
sl933
sl933 over 4 years ago
My cadence crashed, and I had to restart and remove the lock files.
Post the crash, a cell became corrupted, which I can no longer access. When I try to access the cell, I get the following error:
(DB-270000): dbOpenCellViewByType: Corrupted database encountered: Unable to read design data from design [my_cell_name/schematic]. The long mapWindow cannot determine the byte-swap direction. The value 0x2a2a2a2a is an unexpected value. Try oaScan to scan/repair the database, revert it to a backed up version, or recreate it.
So I ran the oaScan on that corrupted cell, but it returns an error:
ERROR: (OA-131): Corrupted database encountered: Unable to read design data from design my_cell_name/schematic. The long mapWindow cannot determine the byte-swap direction. The value 0x2a2a2a2a is an unexpected value.
NOTE: 1 error encountered that prevents the scan of this database.
No inconsistencies found in 4 databases
- found in 0 of 2 designs
- found in 0 of 2 DMDatas
Finished: oaScan
Is there any other way I can try to salvage the corrupted cell?
I am using version IC6.1.8-64b.500.6.
Sunwoo
  • Quek
    Quek over 4 years ago
    Hi Sunwoo
    It seems that you are using quite an outdated version of Virtuoso (IC618-ISR6). Would you please try oaScan from the latest version (IC618-ISR15)? If your company uses a file server, you can also check if there is a .snapshot or similar directory from which you can recover the files.
    E.g. suppose your path is /net/dir1/dir2/sunwoo, .snapshot directory might be located at /net/dir1/.snapshot, etc
    Best regards
    Quek
    Andrew Beckett over 4 years ago in reply to Quek
    Hi Sunwoo,
    There have been a couple of reports of this message, and sometimes it has been a true data loss (although that is extremely rare (and by extremely rare, I mean extremely rare - I've hardly ever seen this), because there is a lot of care taken to avoid the risk of losing data). As Quek suggested, the first thing is to try using a new version of oaScan from a later version - but you might also want to contact customer support. Worst case you may need to rely on backups...
