  3. Automation in Calculator
  • Replies 19
  • Views 20863
ElectronLearn
ElectronLearn over 5 years ago
I have a design which have 100 nets and same measurements have to be done on them. Manually doing it in Visualization & Analysis XL calculator and adding expression to the ADEL seems never ending task. How can I automate it? Please help.
Sheenu
    Andrew Beckett over 5 years ago in reply to ElectronLearn +1
    It's because the string contains quotation marks - and so the string will end as soon as the first quotation mark it finds within the sequence of characters unless you escape them. So you'd need to do…
    Hi Sheenu, Yes, that would be axlAddSpecToOutput() . If you were using Explorer/Assembler, there's a simpler interface using maeSetSpec(). Andrew.
  • ElectronLearn
    ElectronLearn over 5 years ago in reply to Andrew Beckett
    When I am using this fucntion as,
    axlAddOutputExpr("session11" "tb_usr1_clk:tb_driver_1440um_singleroute:2" "ttttdsfdt" ?expr "riseTime(clipX(v("/CLKP_120u" ?result "tran") 863.6E-12 5.0E-9 ) 0 nil VAR("supply") nil 10 90 nil "time" )")
    Its giving syntax error pointing at the ?result part. I have used this expression from calculator which is able to correctly evaluate this. The thing is the function should directly take whatever is in "" as string and should be able to put it in adexl.
    So I tried this,
    axlAddOutputExpr("session11" "tb_usr1_clk:tb_driver_1440um_singleroute:2" "ttttdsfdt" ?expr "abd")
    And it passed whereas "abd" didnt even mean anything.
    Why is this error then coming in the upper use case. How can I forcefully impose something as string?
    It's because the string contains quotation marks - and so the string will end as soon as the first quotation mark it finds within the sequence of characters unless you escape them. So you'd need to do:
    axlAddOutputExpr("session11" "tb_usr1_clk:tb_driver_1440um_singleroute:2" "ttttdsfdt" ?expr "riseTime(clipX(v(\"/CLKP_120u\" ?result \"tran\") 863.6E-12 5.0E-9 ) 0 nil VAR(\"supply\") nil 10 90 nil \"time\" )")
    You'd need to do the same if using the function I provided you with above:
    CCFaddManyExpr("tb_usr1_clk:tb_driver_1440um_singleroute:2" "riseTime(clipX(v(\"/%s\" ?result \"tran\") 863.6E-12 5.0E-9 ) 0 nil VAR(\"supply\") nil 10 90 nil \"time\" )" ?outNameTemplate "rt %s")
    So all embedded quotation marks need to be prefixed by backslash to escape them so that they are not interpreted as the end of the string (or the start of another one).
  • ElectronLearn
    Is there a function by which I can add spec(range or less than or greater than a value etc) to each of the measurements?
    Sheenu
    Hi Sheenu,
  • ElectronLearn
    I wish to add spec specific to a particular measurement on these nets. I wish to check if a string contains "risetime", it doesnt matter if its is risetime_net1 or risetime_net2, meant to say I wish to check risetime* in a string. How can I use wildcard in string for comparison?
    Sheenu
    Hi Sheenu,
    If you're asking how to do this in general for a string, then it would be:
    when(index(theString "risetime")
       ; do what you want when it matches
    or using regular expressions:
    when(pcreMatchp("risetime" theString)
    The benefit of pcreMatchp is that you then can have full regular expressions - so it could be "^risetime.*" which would mean anything beginning with risetime followed by any number of any character; strictly speaking the pattern doesn't need to be "anchored" though - so the trailing ".*" isn't really needed here.
  • ElectronLearn
    In this following code, this error is coming,"pcreMatchp: argument #2 should be either string or a symbol"
    axlSess=axlGetWindowSession() ;To get active adexl session
    sdb=axlGetMainSetupDB(axlSess)
    foreach(testName cadr(axlGetTests(sdb))
    sevSess=axlGetToolSession(axlSess testName)
    asiSess=sevEnvironment(sevSess)
    foreach(output asiGetOutputList(asiSess)
    outname=output->name
    when(pcreMatchp("Risetime" outname)
    printf(" %s : %L\n" output->name output->expression))
    I am not able to figure out why this is occuring.
    If you have any outputs which don't have a name, then output->name will be nil (this could be signals). So you should do:
    when(outname && pcreMatchp("Risetime" outname)
    You could also use:
    foreach(nameExpr sevGetExpressions(sevSess ?namedOnly t)
      when(pcreMatchp("Risetime" car(nameExpr))
        printf(" %s : %s\n" car(nameExpr) cadr(nameExpr))
    Note that when using sevGetExpressions it returns a list of lists, with the first element being the name, and the second being the expression (as a string).
  • ElectronLearn
    Oh I got it Andrew, thank u. It was "nil" which was creating issue!
