  3. Automation in Calculator
  • Replies 19
  • Views 20849
ElectronLearn
ElectronLearn over 5 years ago
I have a design which have 100 nets and same measurements have to be done on them. Manually doing it in Visualization & Analysis XL calculator and adding expression to the ADEL seems never ending task. How can I automate it? Please help.
Sheenu
    Andrew Beckett over 5 years ago in reply to ElectronLearn +1
    It's because the string contains quotation marks - and so the string will end as soon as the first quotation mark it finds within the sequence of characters unless you escape them. So you'd need to do…
    Hi Sheenu, Yes, that would be axlAddSpecToOutput() . If you were using Explorer/Assembler, there's a simpler interface using maeSetSpec(). Andrew.
    Sheenu,
    Probably the simplest (especially as you're using the elderly ADE L tool) would be to use Outputs->Export, then update the CSV file in a text editor or with a script, and then do Outputs->Import again,
    If you were using the newer Explorer tool you could use the maeAddOutput function to add output expressions using a loop to build the expressions you need.
  • ElectronLearn
    ElectronLearn over 5 years ago in reply to Andrew Beckett
    Is this function "maeAddOutput" available in ADEXL?
    No, but it is in ADE Assembler.
    ADE L/XL have been in "sunset mode" for a while, with no new developments. If you're using IC617 or later, you really should be adopting Explorer/Assembler if possible - there are all sorts of features, performance improvements, and automation that is possible with the newer tools that wasn't possible in the past.
    That said, if you're really constrained to ADE XL for some reason, in ADE XL there is the axlAddOutputExpr function which could be used instead.
  • ElectronLearn
    Thanks Andrew. It would be great if u can help me locate this function also.
    What do you mean? I already told you the name of the function...
  • ElectronLearn
    I meant to say where in the menu of ADEXL can I find functions. I hope this is not in calculator. Is it related to Ocean scripting?
    This is not a menu. This is a SKILL function that you could use to automate the creation of the outputs. Let me put together a simple example to show the principle. Are all the nets you are wanting to make these measurements at the top level of your testbench? So in other words, if I gave you a sample piece of code which created a bunch of similar output expressions (and you can adapt the code to change it to your desired output expression) based on the nets/wires selected in the testbench schematic, would that be OK? I'm trying to avoid you having to type a list of net names.
  • ElectronLearn
    Oh I see, as I have always used the GUI, so I was not much aware of the programming languages, by way of which we can run things in virtuoso. Now I got your point. Surely a sample code would help. So it goes like this, I have to make a file and write code in it and then can run(load) it in CIW which will populate the expressions in ADEXL/Assembler, right?
    OK, here's some sample code:
    procedure(CCFaddManyExpr(testName template
        @key
          (outNameTemplate "")
          (session axlGetWindowSession())
          (nets geGetSelSet())
      let((netNames netTable)
        ; this first bit is just to take selected wires, or a list
        ; of net names as strings, and uniquify and sort the list
        netTable=makeTable('netTable nil)
        foreach(net nets
          cond(
            (stringp(net) netTable[net]=t)
            (dbobjectp(net) && net~>net netTable[net~>net~>name]=t)
        netNames=sort(netTable->? lambda((a b) alphaNumCmp(a b)<0))
        ; Then loop through all the sorted net names and build expressions
        ; to add into the outputs
        foreach(netName netNames
          axlAddOutputExpr(
            session
            testName
            lsprintf(outNameTemplate netName)
            ?expr lsprintf(template netName)
        t
    I suggest you put this in a file, and then in the CIW, do:
    load("thefile") ; whatever file name you stored the code in is the argument (in quotation marks)
    Then having done that, have your ADE XL view open, and over the test name do right mouse->open design in tab. On the resulting schematic tab, select the wires on the nets you wish to add (you can also select in the navigator). Then if you wish to add an expression such as VT("/netname") then enter (in the CIW):
    CCFaddManyExpr("myTest" "VT(\"/%s\")" )
    The idea is that you use '%s' where you want the net name to be. The backslashes are do deal with embedded quotation marks within the string. So this could be something more complex, and you can also specify a name for the output too if you wish:
    CCFaddManyExpr("myTest" "settlingTime(VT(\"/%s\") 0 t 1e-07 t 1) - 5e-08" ?outNameTemplate "settling %s")
    In the above "myTest" is whatever test name you're adding the outputs for.
    Of course, if you don't like what it just added, you can select them all and delete interactively.
    Hope that help!
  • ElectronLearn
    Thank u Andrew !
