  3. Why did I get the error message in Dynamic parameter setting...
  • Views 13876
Why did I get the error message in Dynamic parameter setting?
ichiro
ichiro over 5 years ago
Ichiro
    Hi Ichiro,
    This looks as if it may be the same issue as described in this article (I also checked the related CCR) Dynamic parameters table behaves inconsistently. You didn't mention which version you're using, but this should be fixed in IC6.1.8 ISR14 or ICADVM20.1 or later. The article also includes a patch for older versions.
    If it's not fixed by that, please contact customer support.
  • ichiro
    ichiro over 5 years ago in reply to Andrew Beckett
    Hi, Andrew,
    "Although CIW-->Help-->about Virtuoso" shows "version IC6.1.8-64b.500.1", I don't know how to check my tool's version..
    Andrew Beckett over 5 years ago in reply to ichiro
    That is the version. You're using ISR1. The fix is in ISR14, IC6.1.8-64b.500.14 (the final number is the "ISR" number).
  • ichiro
    Oh.. OK, thanks.
    I found a ISR14 directory in our tool directory.
    I'll call our support team.
    Ichiro
